My goal is to get a camcorder that will allow me to do a live stream and also record to either a flash memory card or a hard drive. I know a lot of camcorders can do this through firewire, but I have also read that if I am trying to encode the stream into flash with FME that I shouldn't use camcorders that record in a compressed format.
If my thinking is correct above, then ideally I would want a camera that can send out uncompressed footage to my computer while at the same time saving a copy onto the camcorder. And since the uncompressed footage would be a large file, I would want the file that is saved onto the camera to be in a compressed format.
Most of the filming I do is out in the field where I have to use my laptop and a wireless internet connection. I know I could record to DV tape but I want to be able to have a digital copy at the end of the day that I can archive without much work after a long day. Also not sure how much storage a DV tape could hold. I sometimes have about 15gb of SD footage at the end of the day with my current camera. (Sony Xacti HD1000)
Make since? Not sure if I explained it the best way. Any help would be greatly appreciated.
Originally Posted by shane123
Also, describe what you are shooting in the field (camera connected to laptop?) and how many hours does 15GB represent?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks for the reply, actually I have not streamed from the field yet, this is something that i am wanting to do. I want to be able to go camcorder --> computer (encoding) -->wireless to Ustream or Mogulus.
If all goes well, there is no editing when I get home, just grabbing a copy of the files and uploading the different segments to YouTube. We put up the raw footage 95% of the time, so no editing.
15GB is about 8 hours of footage, its not always that much, just the high end.
So we have 2 ways that we want to put up footage, 1) Live stream 2) Upload to YouTube after everything is over. -
Originally Posted by Adobe FME FAQ
An uncompressed camera feed is impractical for a laptop especially in the field. You want to avoid GOP based interframe compression for best Flash encoder performance. For that a DV camcorder feeding over Firewire is the next best to uncompressed since each field is intact.
Real time FME encoding will be limited by the laptop CPU. Non-realtime encoding will get better quality.
DV format recording consumes (~13GB/hr or ~100GB for 8 hours). This should be done to the laptop internal drive if the CPU is going to be max'd out doing FME.
A major issue is getting a wireless connection with adequate uplink sustained bit rate.Recommends: Kiva.org - Loans that change lives.
"Non-realtime encoding will get better quality." I don't mind some type of delay even if it is up to 5 minutes. Could you direct me toward some equipment that would do this?
I know I am limited on equipment based on budget, just trying to get the best thing on the consumer level at this point.
For the sake of doing a live feed, do you think I should direct the majority of my expenses to equipment for off loading my CPU?
Is there a DV camcorder that can hold up to 100GB of video or is my only option to save the live feed to the computer hard drive while trying to encode?
Thanks for your help. -
MiniDV tape records 62 min. You can buy a Firestore drive in various sizes but the laptop can record while encoding. You still need to be connected to the laptop to stream.
http://www.videonics.com/solutions/video_production.asp
http://www.adorama.com/VDFEFS4PH80.html?sid=1240878377202950Recommends: Kiva.org - Loans that change lives.
HD Camcorder (60fps), Firewire for streaming application to a Mac Mini
By joedom in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 4th Nov 2010, 12:26 -
streaming from camcorder sony dcr-hc42e to my windows 7 32bit laptop
By wfareed in forum Video Streaming DownloadingReplies: 6Last Post: 20th Oct 2010, 05:54 -
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 11:15 -
Best/Least Expensive Camcorder for Streaming (Straight to HD)
By enter8 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Dec 2007, 18:23 -
Daytek DVR-P30: lots of 'fails' when erasing, lots of nothing when recordin
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Jul 2007, 15:43
