  1. Member Teutatis's Avatar
    Sep 2004
    I need to get a new video card, and have this motherboard, which has only PCI Express 1 slots (MSI K8N Neo4 Platinum). If I buy a video card with a PCI Express 2.0 interface, will it work on my motherboard?
  2. Member Skith's Avatar
    Bottom of the ocean
    Yes, a 2.0 card will work in a 1.0 slot. At least it should assuming the manufacturer followed the PCIe specifications.
    The most important thing is to make sure your PSU can handle your new card. Some of the higher end cards draw a lot of power, so be sure to check.
    note: I am using a card with a higher PCIe revision in a board with a lower one, the Asus A8N-SLI Premium.
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
  3. Member Teutatis's Avatar
    Sep 2004
    Thanks. Just ordered an ATI 4350. I have a 480W power supply, so it should not be a problem.
    canada
    A 2.0 pci-e wont work in all 1.0 boards which i found out when i bought a 8800gt and put it in an asus m2v,seems like via chipsets were having issues with 2.0,make sure your board doesnt have that problem,if its nforce then it should be ok.
