Hi ... I have this movies which came in separate AVI files . Each file is about an hour long . Is there any tool or program which will join these 2 files together and make it like a single movie ?
XP Pro sp3 ...
Nero8
Virtualdub - using the same technique that Baldrick is talking about.
Believing yourself to be secure only takes one cracker to dispel your belief. -
VirtualDub's a little more strict on the conditions of the joining, though. The two videos to be joined have to have exactly the same encoding details (video and audio).
If cameras add ten pounds, why would people want to eat them? -
Shouldn't that be a given? Otherwise, you run the risk of the audio being a different length than the video.Originally Posted by Ai HaibaraBelieving yourself to be secure only takes one cracker to dispel your belief.
Oh, definitely. I think AVIdemux is supposed to be a little easier to work with than VirtualDub when joining videos, though, and that's what I actually intended to say.
Thank you ... And yes this one is easier than VirtualDubOriginally Posted by Baldrick
...but Virtualdub will refuse to join two clips that it created itself using the exact same specs because it decided to put a 1 at the end.Originally Posted by Dv8ted2
EXAMPLE: 29.970000000000 and 29.970000000001
How do I losslessly join 2 DV-AVI files?
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 14th Nov 2010, 11:07 -
Join AVI files??
By bagmand22 in forum Authoring (VCD/SVCD)Replies: 16Last Post: 14th Feb 2010, 03:42 -
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 12:49 -
Easy way to join 2+ AVI files
By AppzBeWarez in forum EditingReplies: 2Last Post: 7th May 2009, 23:48 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
