Can VirtualDub record VHS tapes to AVI format?
If so, how can I do this?
I have an old VHS player which my father bought back in the mid 1990s and it still works...
Is it true that AVI movies can be burned straight to DVD-R and played in a DVD player that is DivX compatible?
Is it also true that one DVD-R (4.7GB) can house up to 3 to 4 AVI movies?
You need a video capture device/card to record video from a VCR.
Whether or not a DVD player that supports Divx will play AVI files depends on various options that might be used during encoding to AVI. Anything listed here might be a problem for some DVD players:
https://forum.videohelp.com/topic352457.html
Yes, you can burn several AVI files on one DVD disc if you wish, but the more files you have, the smaller they will have to be to fit on the disc and the worse the quality will be. -
Okay, how many AVI files would you burn into the DVD-R in order to maintain VHS quality?Originally Posted by jman98
VHS = ~352x480
After proper deinterlace, a 45-minute video would occupy a 512x384 size, and be 350MB.
MPEG-4 (like divx) compression also need pre-filtering to reduce noise.
Do the math.Want my help? Ask here! (not via PM!)
What is the best format to convert VHS-C tapes to?
By Theresa in forum Newbie / General discussionsReplies: 16Last Post: 15th Jun 2014, 11:26 -
Which recorder and video enhancer do I need to record my VHS tapes to DVD?
By cnyeco1 in forum Authoring (DVD)Replies: 6Last Post: 26th Oct 2013, 06:13 -
Convert VHS or U-matic tapes to any digital format
By predatorz6 in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2012, 08:36 -
Converting Analog Tapes (from CCTV) to Digital Format (AVI, MPG...etc)
By leungjing in forum Video ConversionReplies: 2Last Post: 7th Sep 2009, 14:22 -
Converting old VHS-C and Hi-8 tapes to AVI files--HELP!
By molon labe in forum Newbie / General discussionsReplies: 10Last Post: 19th Dec 2008, 19:28
