HI
I have a few series of anime which is in RMVB LQ format and I wondering the best way of converting it to higher quality.
RMVB files size 50-90 MB differs between anime series
thanks
Honestly, you can't. What's gone is gone, and you can't get it back.
Depending on the problems you might be able to make incremental improvements, but everything has a trade off and a cost. Cost one is that any changes you make will require you to re-encode, which takes time and risks quality. Highly compressed video often shows blocky artifacts from the compression. There are filters to try to reduce or remove these artifacts, but they can also cost you detail in other areas. RMVB is probably the worst format to work with as few programs handle it well.
It is far easier to improve good quality source that it is to rescue low quality downloaded video. Your best bet is to find a better source.Read my blog here.
What?! You guys are insane.
I routinely convert my VCDs to HD, with 9.7 surround. At 25 cents a disc for the latest releases, it doesn't make sense to buy Blu-Ray. -
"You can't make a silk purse out of a sow's ear."
9.7 surround?
Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face." -
Supreme2k,
That's some serious bass you have in that setup... I'm with you on the VCD -> Bray conversion. I've got my orignal Betamax on its fourth upgrade now. The initial adapter I built for Beta to VHS wasn't too bad. Radio Shack had the needed parts. Putting a in a CD player to get VCD to play was a little tougher. Lots of wires in those IDE cables to get soldered just right. The next step to DVD was easy: just replace the laser - Viola! I even had a little foresight and got a blue laser. Paid off since now my Blu-Rays play perfectly! The upconversion is incredible from that old player - on composite cables too!
Now, to replace that wired remote with a wireless one and I'll be all set.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Originally Posted by Supreme2k
I routinely convert VHS to DVD in better quality than the VHS was -- not a joke, I'm being serious -- but that's about the extent of it. You still have leeway with analog.Want my help? Ask here! (not via PM!)
Need assistance with Higher Quality Stream
By js1974 in forum Video Streaming DownloadingReplies: 0Last Post: 30th Aug 2010, 20:09 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 22:33 -
Converting VHS to DVD: Higher Quality Recordings
By Deter in forum DVD & Blu-ray RecordersReplies: 10Last Post: 16th Dec 2007, 03:47 -
Is higher bit rate = better quality??
By imdaman in forum DVD RippingReplies: 5Last Post: 13th Sep 2007, 08:37
