Hi....
I'm thinking of updating my computer from Windows XP 32 bit to Vista 64..... However at the
Hauppauge site I only see Vista 32 drivers.... Will these drivers work with Vista 64?
I'd prefer a 64 bit os to get past the 4 gb memory limit of Win32...
Cheers
Kenmo
Results 1 to 11 of 11
Probably not.Originally Posted by kenmo
What do you do that requires more than 4 GB?Originally Posted by kenmo -
This.Originally Posted by jagabo
I had a PVR-250 but I don't think I ever tried installing it on my machine since I had two of the newer Hauppauge HD tuners instead. I am thinking since the driver is dated 2005 that it isn't going to work with a 64-bit OS. Vista 32 maybe.FB-DIMM are the real cause of global warming -
3D rendering, photo editing on large raw files, Corel Painter, etc...Originally Posted by jagabo
Take a peek at my gallery....
http://kenmo.zenfolio.com
Cheers -
Well the new version of PS and the patch for Lightwave will let them address more than 4GB. I think 3ds Max is also 64-bit native now as well. I don't think the Corel suite is up to that just yet.
Why would you want the TV tuner on the same system? Just leave it in a separate box and build up the workstation.FB-DIMM are the real cause of global warming -
I realize there is 64 bit 3D rendering software. A 32 bit image editor will benefit from a 64 bit OS and lots of memory if there are big 3d renderings going on in the background. I just wanted to make sure the OP understood that you don't automatically get more performance by jumping to a 64 bit OS.
I use e-on's Vue Pro Studio and version 7 is now available in a 64 bit version.... Posters at Renderosity and at e-on's forum claim there is a big difference in rendering large scenes in Vue 64....
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
PVR-250 vs Newer Hauppauge cards
By statman24 in forum Capturing and VCRReplies: 10Last Post: 21st Nov 2008, 23:13 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19 -
new pc and my hauppauge pvr 250
By heman28 in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Jan 2008, 08:33 -
Want to replace Hauppauge pvr 250, what should I get?
By heman28 in forum Capturing and VCRReplies: 9Last Post: 25th Jan 2008, 09:25
