I wish to use 6 chan AC3 instead of 2 chan AC3 with video I have thats in MKV
The 2 chan AC3 file is in perfect sync when remuxing with video into MKV
the 6 chan AC3 file is out of sync
How can I correct this out of sync problem?
Here is info from Delaycut
Code:***********AC3 info thats in sync********** ====== INPUT FILE INFO ======================== File is ac3 Bitrate (kbit/s) 384 Act rate (kbit/s) 384.000 File size (bytes) 403215360 Channels mode 2/0: L+R Sampling Frec 48000 Low Frec Effects LFE: Not present Duration 02:20:00.320 Frame length (ms) 32.000000 Frames/second 31.250000 Num of frames 262510 Bytes per Frame 1536.0000 Size % Framesize 0 CRC present: YES ============================================= ====== TARGET FILE INFO ====================== Start Frame 0 End Frame 262509 Num of Frames 262510 Duration 02:20:00.320 NotFixedDelay 0.0000 ============================================= **********AC3 out of sync************* ====== INPUT FILE INFO ======================== File is ac3 Bitrate (kbit/s) 448 Act rate (kbit/s) 448.000 File size (bytes) 470747648 Channels mode 3/2: L+C+R+SL+SR Sampling Frec 48000 Low Frec Effects LFE: Present Duration 02:20:06.208 Frame length (ms) 32.000000 Frames/second 31.250000 Num of frames 262694 Bytes per Frame 1792.0000 Size % Framesize 0 CRC present: YES
It needed a 2 second speedup to the audio which Delaycut did rather well.
I read alot of your posts in other threads which described exactly how to use the program, many thanks.
Is it possible though, does a software exist that would modify the number of frames and duration so it could be exact?
Frame length and Frames/second are identical in both files, it's only
Duration and number of frames that don't match.
The solution you provided worked quite well, but could there be a precise way to alter the out of sync ac3 to match info of ac3 in sync?
If so how would one go about it?
Thank you again for your helpful advice. -
No. That's why I had a question mark after my guess of 5888ms. 5.888 seconds is the difference in length between the 2 audio files but, as you found out, it doesn't necessarily follow that the delay is +/- 5888ms. It's so simple to figure out the delay, though, within a reasonable margin or error, that I don't worry about any "scientific" way to figure it out.Originally Posted by B2K24
delaycut - ac3/eac3/dts/mpa/wav delay+cut tool: v1.4.3.2
By amtm in forum AudioReplies: 21Last Post: 23rd Nov 2011, 09:34 -
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 05:18 -
Odd ac3 sync problem
By mayancastle in forum DVD RippingReplies: 7Last Post: 24th Jun 2009, 22:34 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24
