    Apr 2009
    Australia
    Unable to change the project default setting from loop to PAL........any suggestions would be welcome
    Gen
  2. What happens???
    All grayed out, error message, change not accepted, settings not saved...?
    Apr 2009
    Australia
    Originally Posted by borax
    What happens???
    Greyed out options
    Gen
  4. Probably you have opened a project file and tried to change these settings 'afterwards'. As these settings concern the initializations of menus, movies... they cannot be changed when anything is already inside the project (film, menu, images...).
    See: http://download.videohelp.com/gfd/Help/DefaultSettings.html
    Try to change these settings BEFORE you do anything else (load a project, add a movie/menu...)
    Apr 2009
    Australia
    Borax,
    Thanks for your help. I eventually reinstalled the program and started from scratch. But I have an addition problem....see GUI DVD author : Show DVD problem
    Gen
