I have for the last few years used Audio DVD Creator to put 100 or so CD tracks (audio tracks in *.wave or *.cda files) on a DVD. But today I switched to from XP to VISA and the software no longer works.
Is there a software that does that .............and is VISA friendly?
tryin' bryan
too bad that VISA isn't compatible. I like mastercard better myself
I don't know if it will work or not but try installing and running using the XP compatiblitity mode of Vista.Donadagohvi (Cherokee for "Until we meet again") -
Thank you for the excellent suggestion. But how do I run the "XP compatiblitity mode of Vista" ??? This is completely new to me so please explain in some detail.
tryin' bryan -
R click on the program and select 'Properties' at the bottom of the list. You will see 'Compatibility'. Choose XP SP2, then try an install. You can also select 'Run as Administrator' while you're there.
Most programs will run fine with Vista. It's mostly the older ones or ones that use a few non-standard 'tricks' that Vista doesn't like. One Vista compatibility list is here: http://www.iexbeta.com/wiki/index.php/Windows_Vista_Software_Compatibility_List -
If you don't have any luck with your software there are plenty of others out there, try Googling. I see that minor upgrades are free for Audio DVD Creator but I could not find any info on Vista compatibility.
Auto DVD Rip - Put the disc in the tray and the program does the rest
By dw-wizard in forum DVD RippingReplies: 8Last Post: 16th Feb 2012, 23:54 -
Wanted to put 4 CD's on one DVD
By happydog500 in forum AudioReplies: 2Last Post: 16th Sep 2011, 19:15 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
how many xvid can i put on 1 dvd
By peterg60 in forum Newbie / General discussionsReplies: 13Last Post: 19th Jan 2008, 05:56 -
How can I Put PowerPoint on a DVD?
By jrhx in forum Authoring (DVD)Replies: 35Last Post: 26th Jun 2007, 13:07
