I am doing a pretty simple video project for my drawing final. I have
some skating videos but what I want to do is add in my own animation during certain points in the video. Im going to hand draw the stills since I
don't have my mouse or tablet with me to use on photoshop.
I plan on capturing each frame I want to draw and print it out and then
draw it out. How should I go about inserting those back in? Can I just
scan them? I need to make sure the resolution is on the same page as
the original video and I need to keep it level. Please help. If you're still having trouble understanding what I am asking for please let me know so I can try to explain it better.
Also, do you think imovie would be a decent enough program to do what I need done on or should I look for something else?
A hastily reply is appreciated.
Thanks!
	Without a mouse, even the video editing is going to be slow. To be honest, trying to print the frames out and drawing by hand is fraught with problems unless you work for Disney. I'm not sure whether you are talking about animation over the top of the video or just cutting away from the video and having an animation sequence.
 If you are thinking of drawing on the paper, scanning and reinserting frames, the chances of the colour tone being the same as before is zero. It will be different.
 Simple animation over the top of the video:
 You don't say how complex the drawing is. I'm assuming one colour line drawing. If I really could not draw on the actual video frame I would first print the frame at correct proportion. Remember that your video may be 720x480 (3:2) but is say 4:3 on the screen so you must print the video stretched to 4:3 so that you can draw normally. If you are capturing from screen then the aspect should be OK. If you use thin white paper (like tracing paper that you can partially see through) you can draw your animation with the paper on top of the video frame print. If you want the lines to be white you will have to use coloured paper (see later) and white paint.
 Having done the drawing you scan just the animation, not the video frame. Depending on editor you may have to change their aspect back to the video aspect. In the editor you put the animated frames on another track, stretch each timewise to fit its equivalent frame on the main video track. Now you have to use a chroma key filter (colour mask) to make the white (or paper colour) transparent leaving only the animation lines. There are several ways to do these procedures but I can't write a manual here.
 Don't know imovie but you will need a fairly decent editor. Sometimes you have to use methods to suit the software you have. If you don't know the capabilities of your software and have not done this sort of thing it's sort of beyond explanation in a forum like this. You seem to be in a hurry.
  Some Simple AviDemux Questions - iPhone videoBy hech54 in forum Video ConversionReplies: 9Last Post: 27th Oct 2011, 10:45
  help required on making simple but 'deep' dvd menusBy lancealittle in forum Newbie / General discussionsReplies: 9Last Post: 18th Sep 2010, 07:34
  Two simple questions, plz help!By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 11:47
  Need simple guide on making AVIs compatible with Xbox360By sad_muso in forum DVD RippingReplies: 4Last Post: 22nd Aug 2008, 14:12
  Making simple DVD from 16x9 avisBy clawg in forum Authoring (DVD)Replies: 4Last Post: 1st Nov 2007, 22:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
