Hi Everybody,
I borrowed a Canon Vixia HV30 for a couple days which is entirely new to me. Used HDV Splitter to transfer the footage into the computer in scene detection mode. The next step is to fine tune and chop off the unwanted parts at the beginning and end of each clip/scene. What is the simplest and most self explanatory tool to do some basic slicing and dicing?
2) What are the differences between an .m2t (HD) and an MPEG-2 (SD) file?
Is one more compressed than the other?
Does one look better than the other?
Is only the “wrapper” around the video different?
Do you reccomend I convert to an avi file for ease of processing & editing purposes?
With the goal being to get the highest possible product achievable, am I better off to edit
1) A .m2t file on the timeline if the editing program is capable of it or:
2) To 1st demux the .m2t file to a .mpa and a m2v. file which can then in turn be turned into an .avi file? If that's the case what do you all suggest I use to end up with an .avi file?
Anotherwords, would better results be obtained if I did the editing from an .avi file like I’m used to or in some other manner considering the format under discussion?
Also, in mini-dv ( SD) mode, in you opinion will the quality of the video be better in the HV30 or a Canon GL-2 which I have used for a long time? Has current technology improved the price to performance ratio in Canon SD camcorders as the GL-2 is still close to 2K as opposed to the VIXIA can be acquired for $600!
Looking to be educated and know what I should be doing and in what direction I should be heading in fairly short order. Hope the above made some sense.
Thanks for any pointers offered.
Bruce
MPEG-2 (SD) has a different resolution and usually a different bit rate.
If you mean uncompressed AVI, that is also an option but not necessary. It depends on the goals for the project.
Many pros will convert to a digital intermediate format (remove MPeg GOPS) such as Cineform for better timeline performance and better filtering/scaling.
http://www.cineform.com/neoscene/
http://www.cineform.com/pdfs/Workflow_Overview_0904_1.pdf
If you mean convert to an SD DV-AVI file, that is an option.
Normally one would want to retain high resolution. HDV can be edited natively using an editor like Vegas Pro, converted to a digital intermediate format, decompressed or downsized to DV or DVD MPeg2.
Originally Posted by Canon GL-2 GuyRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
HDV .m2t footage - Best quality conversion to MPEG4- method/tools
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2012, 01:30 -
Adobe Bridge m2t files
By vegasarian in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2008, 09:39 -
How to use .M2T files on the Mac
By ArthurDaley in forum MacReplies: 7Last Post: 10th Apr 2008, 03:56 -
Do different pieces of burning software yield different burn quality?
By davlor in forum DVD RippingReplies: 7Last Post: 18th Dec 2007, 08:28 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 04:03
