Is there a way to remove audio hiss using VirtualDub audio filters?
Thanks!
Bob
I have never tried filtering audio in VirtualDub so I cannot help you with that but I suggest that you try a program that is dedicated to sound instead of a video editor. Why not take a look at audacity?
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
The newest version of Audacity (1.2.6) has a much improved noise filter. You take a sample of the noise and it uses that to shape the filter for removal. You can also use the high pass and low pass filters. I've had fairly good results with really bad audio with hum and hiss in the background. You have to be careful not to overfilter, but Audacity does have a 'undo' so you can experiment quite a bit without committing to anything.
Using VirtualDub, I usually use Full audio processing and save out the audio as a WAV. Then import that to Audacity. I leave the file open in VD while I'm working with the audio, so it's a fairly quick process.
When I'm finished with the audio processing, I add the audio file back into VirtualDub, disable or delete the old audio and save the audio and video with Direct stream copy. Use a new file name when you save it so you don't overwrite the original file.
The newest version of Audacity can export in quite a few formats, so it's even better now. -
For quick and dirty hiss reduction, it's hard to beat lowpass filtering. But if you are at all fussy about bandwidth, you might want to consider redwudz's recommendation of Audacity's advanced noise removal functions. Lowpass filtering is very effective at reducing hiss, but at the cost of a rolled-off high end. If you don't care about losing treble and upper midrange freqs, or if the amount of hiss reduction you seek is moderate, then lowpass filtering is the fastest way to reduce (but not eliminate) hiss. Audacity's noise removal function can be as effective at hiss reduction, but often with a less obtrusive reduction in desired spectral content. It can, however, introduce other artifacts, so some experimentation is in order. So you have a couple of good choices, depending on your particular goals.
Use Goldwave, it's only $30.
hiss removal on a good quality VHS tape?
By zee944 in forum AudioReplies: 78Last Post: 26th Mar 2009, 05:28 -
Hiss removal on a bad quality transfer?
By michel weisnor in forum AudioReplies: 8Last Post: 2nd Mar 2009, 13:42 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 05:54 -
audio becomes a hiss
By ballboy in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Jul 2007, 00:03 -
Hiss removal from AC3 file without converting it to WAV?
By Turbo Sensonic in forum AudioReplies: 21Last Post: 7th Jul 2007, 07:18
