i use avidemux to convert a mkv file to avi
this mkv file is playing nicely in media player classic
when i convert it into avi using avidemux
the audio is out of sync
any solution ?
any other good video converter which i can try ?
You can try xvid4psp
Why do you want to convert? You just lose quality if you re-encode. Is this for device compatibility?
If your mkv is vfr (variable frame rate) , it will be difficult to keep in sync because avi container doesn't support vfr
If this is the case, you can search for solutions to vfr, as this topic has been addressed many times. The most common method is using avisynth and a DirectShowSource("movie.mkv", fps=23.976, convertfps=true) script, which doesn't always work. -
Load the avi in AViDemux and use the Shift(ms) tool, play/preview and line it up, save new.avi? Make sure you use 'Copy' profile for both video and audio, so it will/should not re-encode...
You could also try AVI-Mux GUI..." Who needs Google, my wife knows everything"
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
Avidemux edit leads to out of sync audio..
By Jmart285 in forum Newbie / General discussionsReplies: 18Last Post: 18th May 2011, 14:35 -
avidemux audio out-of-sync problem
By scarlac in forum Video ConversionReplies: 3Last Post: 20th Sep 2010, 11:37 -
Avidemux editing causing audio sync issue
By perdomot in forum EditingReplies: 0Last Post: 14th Sep 2009, 15:29 -
AVIDemux / Video and Audio Out of Sync.
By th3obr0 in forum Video ConversionReplies: 7Last Post: 9th Feb 2009, 11:09
