We are trying to hook up a pair of small speakers to the lineout of a sound card and we need a small amplifier to accomplish this. Does anyone have any experience on this?
				Results 1 to 11 of 11
	Easily done. I use an old Sony reciever with the sound cards output routed to the CD or AUX input on the reciever,then hook the speakers to the reciever. works. Far better sound than any computer speaker.
	Thanks for the quick reply.
 We were hoping for a small amp so as hear all the tinkly alerts from Windows and other software.
	You still need an amp. Many sound cards have enough amplification for internal PC speakers (in the case).Originally Posted by mysts
 Describe the speakers you want to use. Most people would use internally amplified speakers.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Something like this maybe.
 http://www.electronickits.com/kit/complete/ampl/CANUK153.htm
 Take +12vdc from a hard disk power connector.Recommends: Kiva.org - Loans that change lives.
	If you don't absolutely have to use your own speakers, go to Google and search on "USB-powered speakers."
 USB-powered speakers eliminate the need for any other power supply, and will produce stereo output.
	why not just buy a new pair of speakers, most PC speakers have their own amp nowadays.
 Also, if your sound is not part of the mother board you might find a jumper on the sound card that will put correct level on the line out to drive the speakers
	thanks for all the suggestions guys:
 I was in Walmart this morning and viola they had exactly what I needed-a pair of Altec Lansing powered speakers.
 So I guess this closes this thread.
  Using PC Speakers on Computer and TVBy imdaman in forum AudioReplies: 3Last Post: 27th Jun 2010, 00:41
  What's a good pair of computer speakers?By Stealth3si in forum Media Center PC / MediaCentersReplies: 16Last Post: 6th Apr 2010, 18:46
  Using computer speakers for my tv.By imdaman in forum AudioReplies: 12Last Post: 28th Nov 2009, 11:47
  How do you play music on the computer using all 6 speakers?By Obamargarine in forum ComputerReplies: 5Last Post: 10th Mar 2009, 17:40
  Best computer speakersBy justalice in forum ComputerReplies: 13Last Post: 11th Apr 2008, 14:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
