is their a program that would allow me to encode my .avi to a HD DVD?
my .avi isnt HD its downloaded of the internet
You won't gain anything by enlarging the frame unless your TV/player has a poor upscaler. Upscaling doesn't create details that aren't there. They simply attempt to avoid creating artifacts while enlarging the frame. And sharpen edges a little bit.
Are you trying to create an HD-DVD, or HD video on DVD? If the latter, you're generally not going to be able to go beyond 720x576, for most set-top players, regardless of whether you're making a DVD-Video disc, or DivX/Xvid videos on a data disc.
[Q] Convert MKV Format Profile from High@L5.0 to High@L3.1?
By xIntenso in forum Video ConversionReplies: 5Last Post: 26th Aug 2013, 21:46 -
Must i convert High@5.1 to Main@L4.0 , how and what settings ?
By G30 in forum Video ConversionReplies: 6Last Post: 25th Apr 2012, 12:18 -
how to convert a dvdrip to high quality
By lordrt in forum Video ConversionReplies: 4Last Post: 25th Jul 2011, 07:30 -
Convert MKV to AVI/MPEG-2 High Quality file for HD author
By ronorkis in forum Video ConversionReplies: 7Last Post: 1st Nov 2010, 08:23 -
Help to convert high definition MKV video to DVD-Player compatible AVI file
By lovecraft123 in forum Newbie / General discussionsReplies: 27Last Post: 1st Mar 2008, 18:22
