I have various music clip collection in VOB format (mixed, both NTSC and PAL). I want create the DVD.
Sure, I need author NTSC and PAL files separately (separate DVDs, either PAL or NTSC) and dont mix them.
I just installed TMPGEnc DVD Author 2.xx, and I am completely new with this program.
Some questions: what way should I use to add VOB files in 'Source setup' screen: 'Add file' or 'Add DVD video'? Is there any need for demuxing first VOB files into audio and video streams? Or this is done by TMPGEnc DVD Author and I dont need additional software? The demuxing will not improve anything in resulting video quality?
Results 1 to 16 of 16
Use 'Add DVD video' if they are in a video_ts folder,If they are vobs without any other files then you will have to demux them and add as file,since its not encoding anything you wont get any difference in picture quality.
You cannot mix PAL and NTSC on a disc, it's not compliant.
I think he just said he wont mix them.Originally Posted by siluetI think,therefore i am a hamster.
Yes, they all are .VOBs without any other files. How to demux them, which program better to use?Originally Posted by johns0
so how to check before dvd authoring that all VOBs have fully DVD compatible GOP structure? If not, there is no way correct this?Originally Posted by noemi7
You can use GSpot: maximum values are 15 for PAL (12 is consider as 'safe'; no clue what max. TDA likes ) and 18 for NTSC. GSpot displays the value as distance between I frames [I <-> I].
TDA is not predictable, and may also rarely dislike something else in m*v/mpg file. However, the GOP structure is the most crucial issue what I observed.
Authoring programs which do not re-encode: DVD Maestro, DVD-Lab Pro, Muxman - it may sometimes fail if GOPs are very long, like over 36. TDA version 1.6 doesn't re-encode as well but it cannot create 16:9 menus, doesn't support subtitles, and limits audio to 1 track only. -
is it important distance between all GOP headers or only distance between first GOP header and 2nd header?
I wouldnt worry about gop structure,just demux and author.
Demultiplexing will not change the GOP structure. You can try to author your vob files directly with Gfd (in dvdauthor mode). But demultiplexing is nevertheless a good idea. With the elementary files you can also use GfD in MuxMan mode (which is more compliant). I had never any issues with a long GOP (dvdauthor doesn't care about it and MuxMan just issues a warning).
If no ifo files are available, try demultiplexing with projectx or dgindex.
All the mentioned programs are freeware.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
You can also use ifoedit to create the missing files,choose create ifo in the menu of ifoedit and add the vobs,make sure the vobs are named VTS_01_1.VOB,VTS_01_2.VOB etc,then you can import the vobs with the newly created ifo and bup files into tmgenc dvd author 2 with add dvd video.
Using IfoEdit to recreate files looks much simpler than demuxing Vobs with DGIndex(which requires also installing Avisynth filter and VirtualDub). Will the preparing dvd files with IfoEdit and importing it into Tmpgenc DVD Author as dvd video provide the same DVD quality as demuxing VOBs into elementary streams and importing it into TDA?Originally Posted by johns0
No quality is lost or gained because its not encoding.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGEnc DVD Author 3 (TDA) Questions
By Brent.M in forum Newbie / General discussionsReplies: 5Last Post: 11th Feb 2008, 00:34 -
ConvertXToDVD, MPlayer and TMPGenc DVD Author 3 basic Questions
By Maikeru-sama in forum Video ConversionReplies: 4Last Post: 28th Jan 2008, 11:43 -
Some questions on TMPGEnc DVD Author 3
By rock_king_my in forum Authoring (DVD)Replies: 4Last Post: 7th Dec 2007, 07:32 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 13:15
