CD-DVD Speed and the more recent DiscSpeed will scan a UDF formatted DVD. The UDF file system is not supported so it does not provide the list of files at the bottom of the ScanDisc tab. Currently I use CD-DVD Speed to provide readability and Explorer to check files are correct size. Does anyone know of a similar utility that recognizes UDF file structure, thus checking the files are both correct and readable?
Results 1 to 1 of 1
Does The Newer UDF Format Take Up More Disc Space?
By Arby in forum Newbie / General discussionsReplies: 12Last Post: 30th Jan 2012, 12:07 -
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 17:18 -
Trying to use MTR to convert UDF disc to other format
By vanzant in forum MacReplies: 4Last Post: 28th Feb 2010, 20:23 -
Burn authored VIDEO_TS as UDF or CDFS (or RAW) file system format?
By PCat in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2009, 16:33 -
dvd writer do not understand ISO9660 UDF format?
By rancid in forum Authoring (DVD)Replies: 17Last Post: 20th Jan 2008, 17:42
