Results 1 to 15 of 15
    Jul 2008
    Netherlands
    Hi,
    I have some issues with converting a .flv file. I've downloaded a live concert from a site (http://www.officinalive.it/pagine/brantbjork.html), and wanted to convert it to mpg to burn on dvd for personal use. With every program I tried (SUPER, Riva, Magic Video Converter, and lots more) it wouldn't work. The programs always tell me the file is encoded wrong, or something like that.
    However, when I try to watch the video, it plays just fine, without any problems.
    Does anybody know what the problem is or how I'm able to convert it?
    Many thanks in advance!
    Kind regards,
    Dirk
    Jan 2007
    Republic of Texas
    One other tool you might try is WinFF.
  3. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Some tools can't handle flv for input. If winff don't work for you try extracting the video and audio with flv extract then encoding those to dvd compliant with tools like hcenc for video and aften/besweet/ffmpegui for the audio. Author those files with something like guifordvdauthor or dvdauthorgui. That is what I do when I need to convert the occasional flv to dvd.
    Donadagohvi (Cherokee for "Until we meet again")
    Jul 2008
    Netherlands
    WinFF didn't work. I got an error and the program craches.
    The FLV extractor also gives me an error: "This isn't a FLV file." I was pretty sure it was a FLV file.
    Kind regards,
    Dirk
  5. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    open the file in mediainfo and tell us what is says.
  6. Originally Posted by canaQ
    This isn't a FLV file, but F4V (similar to MP4).
    Jul 2008
    Netherlands
    General
    Format : f4v
    Codec ID : f4v
    File size : 760 MiB
    Duration : 1h 25mn
    Overall bit rate : 1 240 Kbps
    Encoded date : UTC 2009-01-13 07:13:45
    Tagged date : UTC 2009-01-13 07:13:45
    Video
    Format : AVC
    Format profile : Main@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 1h 25mn
    Bit rate mode : Variable
    Bit rate : 1 120 Kbps
    Width : 800 pixels
    Height : 438 pixels
    Display aspect ratio : 16/9
    Frame rate : 25.000 fps
    Standard : NTSC
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.128
    Stream size : 686 MiB (90%)
    Title : MainConcept
    Language : English
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 1h 25mn
    Bit rate mode : Constant
    Bit rate : 112 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 44.1 KHz
    Resolution : 16 bits
    Stream size : 68.6 MiB (9%)
    Language : English
    So I guess you're right! Should I rename the file to xxxx.f4v?
    Thanks for the replies!
    Dirk
  8. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    I have never seen fv4 so I have no idea but I really doubt that renaming it will help.
    Since Placio74 seems familiar with fv4 perhaps he will have a suggestion.
    Jul 2008
    Netherlands
    Alright, thanks for replying. I'll wait for a suggestion from Placio74.
    Kind regards,
    Dirk
  10. .f4v is a type of flash video , that commonly used with Adobe products
    avidemux should work, and contains internal splitter & codecs so it doesn't rely on system installed ones
    If you want your system directshow filters to function , you need a mp4 splitter such as one from the mpc-hc project. You can register the .ax separately. You also need a h.264 and aac decoder, the most common one being ffdshow. This is probably why the other converters failed, as they uses the system installed codecs/splitters
  11. F4V it's slighty modified MP4.
    FFmpeg have troubles with this file.
    Yamb (MP4Box) re-mux only 3/4 file, but can demux A/V streams.
    Can play in DirectShow (MP4 Splitter + required decoders), but troubles after 3/4 playing.
    Hmm... try Avidemux (can open and convert this file).
    Or use Yamb...
    - change file extension to MP4 (only for visible by Yamb),
    - demux (extract) video and audio tracks,
    - mux (join) again to new MP4 file.
    After, have new 'standard' MP4 file and I don't see any problems with conversion.
    Jul 2008
    Netherlands
    I'm converting the file with Avidemux right now, I'll let you know if it worked or not. Thanks for the useful tips!
    Kind regards,
    Dirk
    Jul 2008
    Netherlands
    Alright, Avidemux did the job! Only one problem, the original file is 800x438 (it's slightly different than 16:9), but as an output I can only choose between 1:1, 4:3 or 16:9. Any tips for this little problem?
    Well, thanks for the very helpfull tips and suggestions! And thanks in advance for this final, small problem!
    Kind regards,
    Dirk
  14. Crop and/or add 'black bars'.
    Also resize to 720x400.
    (Max res for DVD-Video is 720x576)
    Jul 2008
    Netherlands
    That did the job just perfect, thanks!
    Thank you all for your help, I really appreciate it.
    Kind regards,
    Dirk
