  1. Member NotHarry's Avatar
    Nov 2005
    Please would somebody advise me on the best way to convert WMV2 (also known as WMV8) to another format, with the minumum loss of quality, but without greatly increasing the file size?
    What format do you recommend I convert to?
    The reason that I do not want WMV2 / WMV8 is because this format is not supported by my stand-alone media player.
    Can the conversion be done in batch mode on multiple files?
    I also have some FLV filed downloaded from YouTube, and I have the same question about converting these files too.
    Thanks,
    Harold.
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    I guess the first question would be...what formats does your media player support? You may wish to get another media player that supports formats like avi, wmv, flv thusly avoiding any loss from conversion
  3. Member NotHarry's Avatar
    Nov 2005
    Thanks zoobie,
    Codecs:
    MPEG 1 / 2 / 4
    AVI
    XVID
    WMV9(MP@HL)
    H.264(BP@L3, MP@4.0 and HP@4.0)
    AVC(HD)
    VC-1(MP@HL, AP@L3)
    Formats:
    avi
    wmv
    mpg
    iso
    vob
    ifo
    mp4
    asf
    tp
    trp
    ts
    m2ts
    mov(H.264)
    How do you recommend I convert these WMV2 = WMV8 files ?
  4. Banned
    Freedonia
    Are you sure that your WMV files won't play? Have you actually tried this or are you just assuming they won't work? I am not a WMV expert, but surely WMV9 is downwardly compatible with WMV8.
    If you must convert, conversion to H.264 might be good as it offers an excellent balance of high quality and small file size compared to other codecs.
    My PC is too slow to make H.264 encoding practical, so I'll leave it to others to suggest tools for that.
  5. Member NotHarry's Avatar
    Nov 2005
    Definitely.
    There are very very few media players that can cope with WMV1=WMV7 and WMV2=WMV8.
    I got a media player from China that can play, but the remote control and the on-screen menu are so rubbish, I'd rather convert the files if there's an easy way.
