anybody can answer this one?----1st off,i have windows xp--i just bought a kodak m820 digital picture frame,and a sony dcr-hc52 mini dv camcorder--the kodak frame plays videos--the videos have to be in MOV,AVI,MPEG1,or MPEG4 format---the only video program i have is "windows movie maker"---it saves the videos from my camcorder in WMV format,so i can not transfer the video to my kodak frame--so my question is,anybody know a video program that will save my videos from my camcorder in "MOV,AVI,MPEG1,or MPEG4"format?--of course the 1st thing i tried was "video format converter" programs--they dont seem to work--they appear to change the WMV format to MOV,but when i load the movie into my kodak frame,it says "file not supported"---i know my kodak frame will accept true MOV format videos,because i found a MOV video on the internet,saved it,and loaded it right into my kodak frame and it worked----so thats my question-***does anybody know a video program that will save videos from my sony camcorder in true MOV or AVI or MPEG1 or MPEG4 format,so i can load them into my kodak frame?*** i sure would be grateful to u--thnx,Mike................................p.s.--now i have also tried WinDV,which captures the video right from my camcorder and saves it AVI type1 or AVI type2--i made a 20 second video and saved it in both AVI types--loaded them both into my kodak frame,but same thing,when the frame tried to play the video,the frame just says "format not supported"![]()
I would suggest:
1. Open and edit in WMM.
2. Save/Export, but NOT as WMV, but DV-AVI (type1).
3. Download and Install XVID video codec, Lame mp3 audio codec, and MediaCoder converting app (if MC doesn't already include these in its install)
4. Convert you DV-AVI to an AVI or MP4 format using the XVID & LAME MP3 codecs.
Should look and sound good. However, you may have to test excerpt with different target bitrates to find the sweet spot of quality + smooth playback.
Anyone here buy the new Kodak Zi6 HD camcorder?
By snafubaby in forum Portable VideoReplies: 4Last Post: 11th Dec 2008, 01:07 -
Re: Sony Digital Camcorder HDR TG3E Various
By billbirchall in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2008, 13:06 -
Video Conversion Kodak Picture Frame
By Hu Ru in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jan 2008, 14:29 -
help with Digital Picture Frame.
By rmishka in forum Newbie / General discussionsReplies: 1Last Post: 11th Dec 2007, 13:52 -
Kodak Picture CD
By dfluke in forum Off topicReplies: 1Last Post: 12th Jun 2007, 18:34
