  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    ok so Last night my Wired through linksys router internet worked fine. Today turn on pc and no internet? I tried cycling down (Unplug moden/router/pc->turnon modem/router/pc), and NADA. Today when I looked in the network connections. There was a internet connection gateway icon there that was never there before. Under the icon it says internet connection disabled. I tried to enable it but it would just revert back to disabled. Any ideas how to get my internet back up. because Im stumped
    I ran IPCONFIG/All an got this
    ipconfig/all
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : HPa1630n
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Hybrid
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    Ethernet adapter Local Area Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
    Physical Address. . . . . . . . . : 00-18-F3-A6-6B-CB
    Dhcp Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    IP Address. . . . . . . . . . . . : 192.168.1.100
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.1.1
    DHCP Server . . . . . . . . . . . : 192.168.1.1
    DNS Servers . . . . . . . . . . . : 192.168.1.1
    Lease Obtained. . . . . . . . . . : Friday, April 24, 2009 8:28:29 PM
    Lease Expires . . . . . . . . . . : Sunday, April 26, 2009 8:28:29 PM
    I also ran a windows diagnostic and got this
    Last diagnostic run time: 04/24/09 20:38:29 DNS Client Diagnostic
    DNS - Not a home user scenario
    info Using Web Proxy: no
    info Resolving name ok for (www.microsoft.com): no
    No DNS servers
    DNS failure
    info Query [www.microsoft.com] against DNS Server 192.168.1.1, (Type = 0x1, Options = 0x10e8) returns 0x5b4
    action Automated repair: Renew IP address
    action Releasing the current IP address...
    action Successfully released the current IP address
    action Renewing the IP address...
    action Successfully renewed the current IP address
    info Redirecting user to support call
    Gateway Diagnostic
    Gateway
    info The following proxy configuration is being used by IE: Automatically Detect Settingsisabled Automatic Configuration Script: Proxy Server: Proxy Bypass list:
    info This computer has the following default gateway entry(ies): 192.168.1.1
    info This computer has the following IP address(es): 192.168.1.100
    info The default gateway is in the same subnet as this computer
    info The default gateway entry is a valid unicast address
    info The default gateway address was resolved via ARP in 1 try(ies)
    info The default gateway was reached via ICMP Ping in 1 try(ies)
    warn Hostname www.microsoft.com could not be resolved (Error code 0x2afc). Could be either gateway or DNS issue
    action Automated repair: Reset network connection
    action Disabling the network adapter
    action Enabling the network adapter
    info Network adapter successfully enabled
    action Manual repair: Reboot modem
    info Waiting some time for the modem/router to stabilize
    IP Layer Diagnostic
    Corrupted IP routing table
    info The default route is valid
    info The loopback route is valid
    info The local host route is valid
    info The local subnet route is valid
    Invalid ARP cache entries
    action The ARP cache has been flushed
    IP Configuration Diagnostic
    Invalid IP address
    info Valid IP address detected: 192.168.1.100
    Wireless Diagnostic
    Wireless - Service disabled
    Wireless - User SSID
    Wireless - First time setup
    Wireless - Radio off
    Wireless - Out of range
    Wireless - Hardware issue
    Wireless - Novice user
    Wireless - Ad-hoc network
    Wireless - Less preferred
    Wireless - 802.1x enabled
    Wireless - Configuration mismatch
    Wireless - Low SNR
    WinSock Diagnostic
    WinSock status
    info All base service provider entries are present in the Winsock catalog.
    info The Winsock Service provider chains are valid.
    info Provider entry MSAFD Tcpip [TCP/IP] passed the loopback communication test.
    info Provider entry MSAFD Tcpip [UDP/IP] passed the loopback communication test.
    info Provider entry RSVP UDP Service Provider passed the loopback communication test.
    info Provider entry RSVP TCP Service Provider passed the loopback communication test.
    info Connectivity is valid for all Winsock service providers.
    Network Adapter Diagnostic
    Network location detection
    info Using home Internet connection
    Network adapter identification
    info Network connection: Name=1394 Connection, Device=1394 Net Adapter, MediaType=LAN, SubMediaType=1394
    info Network connection: Name=Local Area Connection, Device=NVIDIA nForce Networking Controller, MediaType=LAN, SubMediaType=LAN
    info Network connection: Name=Internet Connection, Device=Internet Connection, MediaType=SHARED ACCESS HOST LAN, SubMediaType=NONE
    info Ethernet connection selected
    Network adapter status
    info Network connection status: Connected
    HTTP, HTTPS, FTP Diagnostic
    HTTP, HTTPS, FTP connectivity
    warn HTTP: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
    warn HTTPS: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
    warn FTP (Passive): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
    warn HTTP: Error 12007 connecting to www.hotmail.com: The server name or address could not be resolved
    warn HTTPS: Error 12007 connecting to www.passport.net: The server name or address could not be resolved
    warn FTP (Active): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
    error Could not make an HTTP connection.
    error Could not make an HTTPS connection.
    error Could not make an FTP connection.
    Thanks to anyone who can figure this one out for me. I have also ran spyware/malware/virus scan, and have ruled all of them out.
    What We Do In Life, Echoes In Eternity....
  2. Member Number Six's Avatar
    Mar 2008
    Why don't you try a system restore and go back 2 or 3 days - before the problem started.
    "I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
    (NO MAN IS JUST A NUMBER)
    be seeing you ( RIP Patrick McGoohan )
  3. bypass the router and connect directly to the modem. the router appears to be non-functional.
  4. Member Number Six's Avatar
    Mar 2008
    Are you using the same router for a wireless connection? Are you connected to the internet right now through the same modem, and are you using a different PC?
  5. Member Cornucopia's Avatar
    Hey, I don't know if this is the same kind of problem, but one that I've been having lately has been that on my self-built Monster Desktop PC, I've been getting "network cable unplugged" and "unable to connect to network" messages. The cable is a known good cable, the router is on and is working fine for both wireless and other (occasionally) wired PCs.
    A reboot not only won't change things, but if you go into BIOS/CMOS configuration during POST, it shows NO NETWORK ADAPTER! (It's on the MOBO), and no way to refind and re-enable it.
    Guess what I tried that seemed to fix it (and this was repeatable, regardless of any other factors that may be influencing the outcome)...
    I powered down, and unplugged the power cable (so it wasn't just a reboot or shutdown), and let it sit for a few minutes. That's it.
    Came back up fine!
    Now, I believe one of the things that was making it continue to occasionally be disabled was probably OVERHEATING.
    But the fix worked.
    Hope that helps,
  6. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    I've had that problem a few times I don't know why. A system restore fixes it every time
  7. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    System restore didn't do the job this time. It usually does for me though. I tried going directly from the modem to the PC, and stll nothing. Had my pal from comcast stop by and it indeed was the modem. Got a new one and now alls good. Thanks for all the replys...
