I have the software as stated in the subject that came with one of my cards. Here's what I do:
I use my laptop hooked up to the firewire output of my DVR and record Hi-Def to my laptop using CapDVHS. All my extensions are set to .ts I then use HDTVtoMPEG2 to convert the .ts files to mpeg files. Now, when I try to import these files in to Quick Studio I get an error message saying the file could not be opened. Any ideas why? When using CapDVHS should I set the extensions to .mpg instead of .ts? Or is there a setting in Quick Studio that allows the file to be read. I can view those files in WMP and VLC player. Why won't they open in Studio?
Thanks in advance!!
dbanimal
As best as I can remember, you need Pinnacle Studio Plus 10.7 to open the file in XP, or 10.8 in Vista.
I'm able to open any other mpg video and create a movie with it, it's just from my DVR that it doesn't want to open that file. I also have WinDVD Creator which came free with a capture device I purchased and I can open those files in there but that software has many bugs.
dbanimal
Pinnacle Studio 8
By Victri in forum Newbie / General discussionsReplies: 1Last Post: 24th Dec 2007, 04:18 -
Pinnacle Studio 11
By fjmr in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 03:44 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
Is anyone using Pinnacle Studio 11 ???
By maxtrack in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 22:56 -
Pinnacle studio quick start help need
By littlesweetboy in forum EditingReplies: 4Last Post: 7th May 2007, 04:46
