I have about 100 little avi clips I'd like to produce a DVD from. Preferably, when complete, there would be 100 chapters; one for each video. While playing, I'd like it to simply go from one to the next automatically.
I was going to use DVDFlick, but it maxes out at 50 from what I can tell. The quality of these is pretty low, so I'm not worried about maintaining perfection here. The total size of the files is 4.1G. I was hoping to get them all on one dual layer disc if possible.
Results 1 to 9 of 9
THe total size of the avi file does not matter when you are converting to dvd-video, ONLY the total running time. So what is it? If too many hours it will look like crap with all tools.
You can also try convertxtodvd. -
Looks like that leaves a watermark unless you buy it. Thanks for the link anyway.
The runtime is probably 200m or so. -
200 minutes is a push for a single layer disc, but OK for a DL disc. If you must go single layer then consider half-D1 resolution.
DVD Flick is free and allows you to put multiple files into a single title, and will put chapter stops at the start of each clip for you.
I believe the DVD specification limits you to a maximum of 99 chapters per title, so if you have more than 99 clips you may have to split them into two or more titles.Read my blog here.
File size = bitrate * running time
That give you around 5500 kbps to work with. Use a bitrate calculator for more exact values. -
Originally Posted by Airjrdnor lose/merge a videoOriginally Posted by guns1inger
Originally Posted by AirjrdnWhich many times translates into "I took a glance at it, but didn't actually try it to test" or "I don't know how to do it." He was probably going by what you implied.Originally Posted by Airjrdn -
Always out put to a Video_TS folder, not an ISO. Do not trust VLC to play ISO files correctly any more - it seems to have become somewhat hit and miss. If you want a free solution, DVD Flick is about it for joining files together nicely.Perhaps you need to create smaller videos, then use PGCEdit to ensure sequential playback of the titles.
Read my blog here.
Out put from avi files
By santolina in forum EditingReplies: 4Last Post: 20th Sep 2009, 12:51 -
How do I take .avi or.mp4 files and put them on a video DVD?
By TripleH in forum Newbie / General discussionsReplies: 6Last Post: 5th Sep 2009, 11:05 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 21:32 -
How can I put movies and data files on the same DVD?
By Sam-SS in forum Newbie / General discussionsReplies: 9Last Post: 29th Nov 2007, 06:50 -
Can I put multiple video files onto one DVD?
By flameout in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2007, 16:12
