THIS IS THE ORIGINAL POSITION
http://www.imgbom.com/images/694_sub.jpg
if i want to made the sub down/below again
HOW IS THE X AND Y VALUE SHOULD I FILL?
thx you
Results 1 to 14 of 14
The .srt format has no support for positioning or formatting subtitles. If you're interested in either, you might consider using the .ass subtitle format.
If cameras add ten pounds, why would people want to eat them? -
You can also adjust the position on playback with most software players. To move it up/down you would adjust the y position.
Oops. Yeah, I should have asked if the OP wanted simply to change where a software player was placing the subs.
well sg99 wasn't very clear on what the format goal was, how it was going to be played ...
Doesnt matter cause srt subs can be moved with software players and home dvd players depending on the program used.Originally Posted by poisondeathrayI think,therefore i am a hamster.
I was actually replying to ai haibara, but you are correct many soft & hardware players can move subsOriginally Posted by johns0
Cheers -
or like this
we change this srt to ifx
then edit at
# Origin, relative to the upper-left corner, can be overloaded by aligment
org: 0, 25
how? -
ifx? Do you mean to say IDX? As in VobSubs (IDX/SUB)?Originally Posted by sg999
Why not just convert to SSA format text based subs (or ASS, as Ai Haibara suggests)? In those you can set the font, size, colors, position, etc. SubResynch (comes included in the VobSub package), among other programs, can do it instantly. -
Originally Posted by sg999Is there something there you don't understand?Originally Posted by manono
yesOriginally Posted by manono
because my SubResynch only can add in english srt
chinese srt look no supported~
sigh~~~
Oh, sorry, I didn't realize these were Chinese subs. How about SubtitleCreator? Did you try that already? It can convert SRT to IDX/SUB (VobSubs), but I don't know how it handles Chinese subs.
how to convert .sup to .srt
By akakiami in forum SubtitleReplies: 20Last Post: 13th Jan 2018, 10:53 -
How to demux .srt from mkv, then convert .srt to .smi and mux .smi to mkv??
By narayanan in forum SubtitleReplies: 1Last Post: 7th Aug 2010, 22:49 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 00:46 -
Working with .sup and .srt
By ma2kp in forum SubtitleReplies: 2Last Post: 8th Dec 2008, 21:34 -
.sub to.srt?
By Hank Kinsley in forum SubtitleReplies: 9Last Post: 14th Aug 2007, 12:25
