Can Vista Corporate Edition be installed on a home computer?
At work we use XP Pro Corporate edition and I've been asked to install the Enterprise Edition of Vista 64 Business at home.
The computer is an AMD Phenom II X3 710 with 6gb of DDR2 memory...
Thanks kindly
Kenmo
You would need a Key Management Server, but yes, it should install. If this is for work, they should have provided you with a workstation that already had it installed.
Believing yourself to be secure only takes one cracker to dispel your belief.
Can I install Win Vista HP with installation CD
By pchan in forum ComputerReplies: 21Last Post: 9th May 2011, 10:37 -
Q's on partioning a hdd and dual booting XP/vista 32bit and win 7 64bit
By Rudyard in forum ComputerReplies: 0Last Post: 14th Feb 2010, 20:52 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 23:51 -
Vista Enterprise problems with WMP 11
By jyeh74 in forum Newbie / General discussionsReplies: 11Last Post: 22nd Mar 2008, 20:18 -
Is DVD-RB compatible with Win Vista???
By Eternal7331 in forum DVD RippingReplies: 3Last Post: 11th Oct 2007, 01:31
