I am NOT sure I an posting in the "Right" section?
I Downloaded a RAR File, and after extracction, what I got is a VIDEO TS File and a .BB File about 2 kb. how do I burn it on to a DVD?
I did create an iso file just with the VIDEO TS, and tried burning it on a DVD with ALCOHOL 120 ,but to no avail..... it did not play at all in the DVD player. Thanks
Thanks a heap. that DID It !!,Originally Posted by redwudz
First , I configured the Mode Tab by checking "Build", Locate the source File, pointed it to VIDEO TS and selected the destination Folder. It ask me whether to label the Volume or Not, and I clicked YES, and Imageburn started to create the .ISO file.
I did nOT know how to Burn it using ImageBurn, even though I looked at the Tutorial, so I ended burning the Created .Iso File with the VIDEO TS in it now using ALCOHOL 120%, and it came out GREAT. Thanks Again for pointing me in the right direction, I would NOT have wasted a DVD..LOL, if I have consuled U first -
In future, use ImgBurn to actually burn the DVD: the entire point of ImgBurn is that its the most careful, accurate burning software you can use. Instead of "build", load a blank DVD and go into ImgBurns EZ Mode Picker and choose the "burn files/folders to disc" option. When the "choose file" dialog opens, click the little folder icon to choose the Video.TS folder you want to make a DVD of. Then click the big icon at the bottom (a file folder with an arrow pointing to a disc). You'll be prompted to confirm a name for the DVD and then it will burn perfectly. No need to switch over to Alcohol.
I will pay more attention to the Settings, this was my First time using ImageBurn. I have always use Alcohol 120 %. Thanks all.Originally Posted by orsetto
I don't think there is a "Difference" using the "Ez-Mode" or the "Build" mode, when One is trying to Burn a Video_Ts folder to DVD. I just did both methods, RESULTS ARE THE SAME ......Originally Posted by niteghost
LightningUK! added the 'EZ-Mode' probably because some people got confused at the names used. 'Build' is the same as 'Write files/folder to disc' in EZ-Mode.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
