I have a dual boot (both XP pro) box with 2 LG burners, a DVD and a Blu-Ray (both are sata drives), where the DVD burner speed is just under 1x with the Primary boot. The BD burner is OK. Tried installing the driver but still same.
With the secondary boot, the DVD burner will max at 6x on the read test with "Nero speed test" which might be a little low but acceptable.
Any one know of any reg settings or simalar DMA/PIO settings for sata drives?
TIA
Try deleting the sata controllers from the device tree and then reboot.
BD-burner writes a BDR but data gets corrupted
By ma-fia in forum DVD & Blu-ray WritersReplies: 6Last Post: 5th Nov 2011, 18:00 -
Is possible to replace a different speed internal DVD burner?
By coody in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Dec 2010, 18:39 -
Lite-On Burner Will Not Read DVD+R Media
By kca741979 in forum MediaReplies: 11Last Post: 28th Feb 2010, 02:47 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 13:36 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 13:58
