  1. Member gooberguy's Avatar
    May 2003
    WNY, USA
    i currently own http://www.newegg.com/Product/Product.aspx?Item=N82E16814130085 and saw this really cheap video card on slick deals http://www.microcenter.com/single_product_results.phtml?product_id=0298462
    do you think its worth paying 20dollars or whatever to get this or would the difference be minimal?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The 2nd link doesn't work. You can compare various card in the VGA charts over at Tomshardware.com
    Google is your Friend
  3. Originally Posted by gooberguy
    Difference doing what? And, as reported, the second link doesn't work. The only card I see under $29.99 at Microcenter is a refurbished Matrox G450 for $9.99.
