Encoding with cce using 3 pass 8000 vbr, 4000 min 9000 max doesn't look good on high motion scenes. (fast action basketball game) It looks like it can't keep up with the action and kind of flashes or has a slight flutter. Does anyone know of a way to improve this using cce? I have done the same thing with tmpg using 2 pass vbr and it works fine with the same settings. It just takes about 4 times longer to encode. If there isn't a way to make this work, I guess I will just stick to tmpg. I just it worked faster. Please help if you can.
Results 1 to 1 of 1
Converting DVD Deleted Scenes to MP4 - Subtitles Don't Match
By rickydavao in forum DVD RippingReplies: 1Last Post: 14th Mar 2012, 01:46 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 07:30 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11 -
jittery slow motion scenes
By Dr_Layne in forum Capturing and VCRReplies: 1Last Post: 25th Aug 2007, 19:36
