Hi, i make my dvd's (16:9 widescreen)with Sony Vegas-rendered progressive movies with Sony Architect, progressive 'auto' function.
When play them in a standalone on a 4:3 tv, you have letterbox strokes up and under the movie.
The line between the movie and the black stroke seems to flash/flicker (jump up and down, at a very quick speed).
Now i made another movie which contains a nice white border/line around it. Now the problem is much worse or visable (contrast white line on black surface).
I can use a 'reduce interlace flicker' solution in sony architect, thinking my problem is something similar? Although this solution is according the manual for still-photos used in a movie. Don't know is i can use this on the movie. Don't if it's interlace flicker.
Possible cause or solution?
What type of TV? LCD, plasma, CRT...? Pretty much the only interlaced TVs are CRT.
The only way you are going to reduce the flicker is to darken the image at the top and bottom edges. The flicker reduction filter in Vegas probably will not help. Try compositing with a black image and an alpha mask. -
didn't know sorry...so i have a crt tv then?Originally Posted by jagabo
http://www.p4c.philips.com/files/2/28pt5105_00/28pt5105_00_pss_nld.pdf -
Yes, that's a CRT. The problem stems from the fact that interlaced CRT displays only show half the picture at a time, alternating display all the even numbered scanlines, then all the odd numbered scanlines. This causes sharp, high contrast, horizontal edges to bounce up and down. The only solution to this would be to darken the picture at the top and bottom edges so that the contrast is reduced.
I wouldn't really worry about the problem. You'll eventually have a widescreen progressive display and the issue will go away.
black border problems
By nospam7676 in forum Video ConversionReplies: 2Last Post: 25th Dec 2010, 16:23 -
encoding black border or not ?
By miss in forum Video ConversionReplies: 1Last Post: 3rd Sep 2009, 09:27 -
Overscan border
By milway in forum Authoring (DVD)Replies: 5Last Post: 1st Jul 2008, 17:03 -
creating a border in premiere
By devdev in forum EditingReplies: 5Last Post: 15th Jan 2008, 15:40 -
Black border around conversion
By trueman in forum Video ConversionReplies: 8Last Post: 26th Jul 2007, 05:50
