    merseyside
    hi,i have a apple ipod nano v3 8gb. these are fake ipods and are only 1gb,this may help with my problem. itunes doesnt work because of the software in these ipods. what i have to do is drag drop which isnt a problem. the problem i have is transferring videos. the sample video already on is a video clip 128 pixels width 160 height,video 64kps,15f/s. i have my own xvids and have converted to mpeg-4 and transferred to ipod. in the ipod i cant see the video. if i go into windows explorer and change the extension to .avi,it then becomes video clip but refuses to play in the ipod. is there something else i need to do,or is it unplayable simply because the ipods are fake? is there any way around this to make them play? cheers
    u know me,i like free tv
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The files need to be in a format supported by the player. In addition to being in a suported format (ie: avi), the files also need to meet the specs supported by the player (ie: 128 pixels width 160 height,video 64kps,15f/s ). The user manual should list the supported file types and specs.
    There are apps in the Tools section for performing the conversions.
    Google is your Friend
    merseyside
    ok,something not quite right here,is it because these are fake?i had a clip already on,a music vid. when i saved it and viewed in media player,the video was flipped 90 degrees.in properties its 128x160,64kbs audio,93kbs video,15 framerate. these are the programs i have used.
    mpegstreamclip
    avidemux 2.4.4
    mediacoder pmp edition
    videora ipod nano conerter.
    all produce same results.
    with mpegstreamclip,i can resize 128x160, audio 64kbs,framerate 15. i have the option to flip the image too.after conversion i rename extension to .avi then i see it in the ipod,just refuses to play it.
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Sounds like your conversions are wrong. You shouldn't have to rename the extension.
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    How are they 'fake'?
    As far as I know, iPods don't support playback from AVI videos. (Which brings me back to the question above, as I don't think the iPod firmware would notice AVI files; they'd probably have to be in a certain folder, though (and I don't know which, sorry. I've always let iTunes (or Videora and iTunes) handle the video cataloging on my sister's iPod.)
  6. Two solutions:
    1 - Use WinAVI MP4 Converter
    Once you convert the videos, you have an option of directly transferring the videos to the connected Ipod.
    2 - Install Winamp & ml_ipod plugin.
    Convert using either WinAVI/any other Ipod converter. Drag n drop the file to the Winamp playlist. DO NOT TRY TO PLAY IT YET. Right click on the file & hit "Send to Ipod".
    Those r the best known workarounds that I can suggest so far.
