Here's a "hail Mary" thing to try: In Word Pad, add a couple of extra characters at the very beginning, and to the very end. Save as "XXXXtemp.srt." Then re-open the file, and delete those extra characters. Re-save and try using that file. There's sometimes a funny end-of-file problem (or a header problem) that can be fixed by this operation. And even if does nothing, at least you'll not have wasted much time in trying it.
Results 31 to 35 of 35
Open the SRT file with Notepad. Does it look ok? I've had problems with Unicode SRT files in the past. I don't remember what the symptom was though.
At last ... I have no idea why TMPgenc didn't like the subtitles, but I just tried WinAvi with the avi & srt in the same folder & it came out perfectly ... I have no idea why, but I think it had something to do with the subtitles - the avi on its own was fine, just went wrong when I put the srt file in the same folder & tried to play / convert it.
Thank you all for your help, guys.
LG RH2T80 - won't recognise DVD's
By Dalene in forum DVD & Blu-ray RecordersReplies: 3Last Post: 16th Oct 2010, 23:34 -
DVDFab won't recognise DVD
By audax in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2010, 00:16 -
Why won't my computer recognise my films from my camcorder?
By Horseysi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th May 2009, 16:43 -
OS won't recognise harddrives
By mysts in forum ComputerReplies: 6Last Post: 9th Mar 2008, 13:57 -
Vista won't recognise my miniDV cam
By ereiamjh in forum Capturing and VCRReplies: 14Last Post: 23rd Jun 2007, 21:53
