i use dvd2svcd 1.0.6 (build 4) to rip scarymovie II duration +/- 80 min
but cinemacraft stops after 2 or 3 passes.
same problem with planet of the apes.
bitrate problem ?
Looks like the same prob mentioned here:
http://www.vcdhelp.com/phpBB/viewtopic.php?t=79661
Tho I haven't really gotten any help with that either :/ -
If you haven't tried the crc error check patch then dowload it and try it, if you have then welcome to the totally undependable world of cce, I have heard that the newer version, 2.62, does not fail as much and the newer version of dvd2svcd can use this version, I finally got my dvd2svcd to work so am not going to do anything to mess it up....lol
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 23rd Aug 2010, 23:17 -
Cinema Craft Encoder Issues converting to 16:9 etc.
By lapetite_66 in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 20:09 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
