what do I need to view movies on my laptop on my tv screen and which is the best way to do this?
Results 1 to 10 of 10
Does your laptop have an S-Video out connection? That would be one way...
If your laptop has VGA or DVI out and your TV has VGA or DVI/HDMI in you can use one of those. In the absence of those or s-video out you will need a scan converter. Keep in mind that s-video or composite video on a TV will not be very clear.
Confirm make and model of laptop.
There are also usb to tv adaptors available for laptops with no vga/s-video/dvi ports
Avoid cheap nasty scan converters for vga to tv as sold in ebay -
My laptop is an Hp dv5-1235, it has both an HDMI port and External Monitor port. My TV has the regular 3 colored [Yellow, Red and White] ins and outs. What setup or device will give me a clear screen from laptop to tv please?
Nothing will give a clear picture with the Yellow composite port on your TV. If your TV only has composite inputs you will have to use a VGA to composite scan converter like this:
http://www.amazon.com/AVermedia-Key-Micro-Scan-Converter/dp/B00006B7F7/
It will be ok for watching youtube videos or streaming video from NetFlix. The Desktop will be pretty much unusable though. It will be hard to read. edDV posted an example a while ago:
https://forum.videohelp.com/topic315232.html#1615925 -
From everything I have read here and the links, it tells me I am better of simply purchasing movies and not concentrate on watching movies on TV from a pc?
Standard definition (or lower) movies can look ok with a scan converter. Composite output from a computer or scan converter can be about as good as composite output from a DVD player.
1: HDMI to Composite or S-Video Converter ... all the bells and price
2: AVerKey100pro,(also require stereo head jack to rca cable for audio) -
Not sure if this is an option for you but, you can always stream(wireless)from the lappy to a media center like device...The PS3 or xBox360 work nicely...Originally Posted by mikehende" Who needs Google, my wife knows everything"
Possible to use laptop screen as external screen?
By WinSpecToR in forum ComputerReplies: 9Last Post: 31st Dec 2011, 11:29 -
Laptop Problem. Cant view certain videos eg TVCATCHUP. plug-in inresponsive
By UmmAddan in forum ComputerReplies: 0Last Post: 6th Sep 2011, 14:41 -
can't view/use DVD_RTAV files on my laptop
By florenceishere in forum Newbie / General discussionsReplies: 3Last Post: 11th Aug 2009, 13:30 -
Vlc media player on laptop hooked up to an "oldfashioned TV to view av
By Tblossom in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2008, 16:40 -
DVD shrink, RipIt4me- how to view on laptop?
By fayewolf in forum DVD RippingReplies: 2Last Post: 6th May 2007, 11:40
