An arithmetical question.
How do you compute correct aspect ratios and borders, so when I resize a file for DVD authoring I end up with the original relationship in a 16:9 screen?
For instance, let's suppose I have three different file formats which I got from MediaInfo:
1) 704:400
2) 1280:688
3) 704:288
Which math formula should be applied to get to an untrimmed correct size, with the right black borders (if any) up and below and no distorted image compared to the original? In NTSC, of course.
well ntsc dvd is 720x480. no other choices to encode to. there are others that work on dvds but not that you'd want to encode to. if it's 16/9 there is a flag the encoder sets to allow the dvd to be played in widescreen.
the first 2 are close to 1.77, the 3rd 2.35., so encode to 16/9 dvd specs and the encoder will add the borders.
any questions make sure to mention which editor/mpeg-2 encoder you are using. -
There are quite a few resize calculators around, some web based. Some go into detail on how they work - non-square pixels etc - most don't. Hell, I even wrote a simple one a few years back -> http://users.tpg.com.au/adslrotx/apps/AVI_RC2.zip (requires .net 1.1)
Read my blog here.
Need help with setting borders for track motion in Vegas Studio
By gtmb in forum EditingReplies: 1Last Post: 20th May 2011, 15:48 -
Help with cropping & adding black borders with Avisynth
By jda in forum RestorationReplies: 9Last Post: 11th Oct 2010, 07:10 -
MeGUI keeps forcing weird aspect ratios how do i force 4:3? & why its 1
By Chrushev in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2010, 08:36 -
Help Aspect Ratios & Frame Rates
By CTP-Crystal in forum Newbie / General discussionsReplies: 21Last Post: 1st May 2009, 18:10 -
AviSynth & Aspect Ratios
By blazin-j in forum Newbie / General discussionsReplies: 3Last Post: 28th Nov 2008, 13:39
