Results 1 to 13 of 13
  1. I have this movie the audio is in english but there is dutch subtitles is there a way to remove the subtitles
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Are the subtitles soft (can you switch them on or off), or are they burned into the video itself?
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Seriously....
    Did you miss the whole Forum
    Subtitle
    Everything about subtitling, adding, removing, ripping, converting subtitles.
    That's like one of the top asked Q's along with zero information included with the Q
    You have this movie eh... well, what format is it ??
    It has dutch subtitles & you want to know if there a way to remove the subtitles ??
    See Ai Haibara's post.
    You are not new and you have more than a few post's.... C'MON!!!!
  4. Originally Posted by Ai Haibara
    I dont really know what you mean by
    or
    where do I find this out I think maybe they are burnt into the video not sure can you help the movie is in 2 seperate folders a VIDEO_TS and a AUDIO_TS VOB files
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You have a DVD. Put it in your DVD player. Start it playing. When it begins the movie, use the subtitle button. If they turn off, your problem is solved. If they don't, you will have to re-encode the movie leaving a blurry pixelated mess in place of the subtitles.
    Read my blog here.
  6. Originally Posted by guns1inger
    so how do I re-encode the movie and you say it will leave a blurry mess where subtitles are so by re-encoding takes subs away
  7. Banned
    Jun 2004
    Of course they will not turn into a blurry spot or vanish if they are hard subs by JUST re-encoding.
    https://forum.videohelp.com/topic366077.html
    On the FIRST page of the CORRECT forum
    Took me all of 30 seconds to go there and look down the page, and that was without even using the super secret hidden search function Baldrick has hidden on the site 8)
  8. Originally Posted by Noahtuck
    well what did you type in search also spill the beans then where is this secret hidden search function also where is the correct forum
    Jan 2007
    Republic of Texas
    Natty, read Noahtuck's posts slowly again. When you posted, you first went to an index of forum topics. (You could not have written your first post otherwise.) Your choice was to write a post under the Newbie > General Discussions forum, when you should have first looked down the index list and gone into the Subtitle forum. In doing so, you would see that your questions have already been answered, many times over.
    And Noahtuck said it could be done "...WITHOUT even using the super secret hidden search function Baldrick has hidden on the site." (My capitalization.)
    Also: like Guns1inger said, if you can turn your subtitles on and off in either the movie's menu settings, or with the Subtitle button on your DVD remote, then the subs are soft and can be taken off. If not, they are hard subbed and you will either need to blur them out or just go and BUY a domestic release of the movie.
  10. Subtitle forum. In doing so, you would see that your questions have already been answered, many times over.
    I have just looked in subtitle forum and I cant see my question there
  11. Banned
    Freedonia
    I will make one attempt with this. natty - the search function is at the top center of the page in the forums. See at the top where it says "VIDEOhelp.com Forum"? Two lines under that is the Search function.
    However, there is one dirty little secret that you will be expected to miraculously know, but no one (but me) will tell you. Search is broken in individual forums and only works if you do it from here:
    Jan 2007
    Republic of Texas
    Geez, it took me all of 15 seconds to find these in the Subtitles forum:
    https://forum.videohelp.com/topic366077.html?highlight=remove%20subtitles
    https://forum.videohelp.com/topic362806.html?highlight=soft%20subtitles
    Anyway, the first step of your question was already answered in this thread: Determine whether you have hard or soft subs through the instructions given in mine and Guns1inger's previous posts.
    And next time you want to start a thread about subtitles, do it in the Subtitles forum.
  13. Originally Posted by filmboss80
    ok will do sorry
