Hey!!!!Here's what I want to know.
Suppose I download a torrent, check its seeders/leechers ratio
Now due to some reason I'm not able to start that torrent.
After 1 week I start the torrent but before I start the torrent
I want to know its current seeders/leechers ratio.
So that It will be better to start it or search for a new (faster) torrent.
Like a website:- http://www.torrentreactor.net/
Tells the current status of the torrent.
So, is there any software that can tell me the current
seeders/leechers ratio for a particular torrent
thnkx!!!![]()
AnonymousGuest
Look at the web site. There is no software needed. The information on the the file will give you what you need.
Believing yourself to be secure only takes one cracker to dispel your belief. -
AnonymousGuest
Thnkx "Dev8ted2"
but what to do if I downloaded 9 torrents a month ago
and now I want to start them.
So to know their current status(Health)
Should I try to find them again on the net
or just start using them via u-torrent or bit-torrent.
that's why I was asking for some software
coz, "torrent-reactor" might be using some technique
to show the current status.
plz reply.
If you have an old torrent; you know what it is for. Just look it up again in the tracker sites using the search and see what is available. Should show stats for the torrent you have if it's not too old.
Just start it going and see who is out there. It will only take a couple of minutes for your torrent program to tell you how many seeds and how many leechers are around. Also, the web status indicators do not include DHT clients. You need to start the torrent to find out how many of these may be available as well.
Read my blog here.
Using a web tracker, is this something bad?
By lana2000 in forum Off topicReplies: 1Last Post: 18th Mar 2009, 09:28 -
Torrent searching engines and torrent softwares
By 1234567 in forum Off topicReplies: 7Last Post: 11th Sep 2008, 03:54 -
torrent file
By freakme in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2007, 17:58 -
torrent downloads
By efiste2 in forum AudioReplies: 11Last Post: 17th Oct 2007, 00:28 -
Myspace Tracker
By DaveLunesta in forum Off topicReplies: 4Last Post: 6th Aug 2007, 00:08
