Hello,
I have teo files: .avi and .srt file in the same folder. Which is the best software to join the in order to burn the result to a DVD please? The CloneDVD software will do this? If so, how?
Thanks in advance,
André Luiz
One option is Convert X to DVD.
There are other but this one is perhaps the easiest -
Thanks for the answer. It is very easy indeed. However, would there be a free software with this purpose? At least cheaper would suffice as well.
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 06:35 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 00:46 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
add/burn srt sub into avi
By volam in forum SubtitleReplies: 2Last Post: 24th Aug 2008, 04:48 -
Adding srt to avi not working
By joesphroth in forum SubtitleReplies: 1Last Post: 31st Mar 2008, 11:34
