Hi, guys. I know I've seen a post where someone laid out a fix if you're having audio sync issues but I cannot find it anywhere, so sorry if it's been posted and I missed it. I could have sworn it involved VLC player so that you can correct the sync and then you input that offset into another program to fix the file. Tried to search for awhile!
Anyway, here is my problem:
I use GOTSent to convert .MKV files to .MP4 so that I can watch them on my 360 with use of an external HD. I do NOT want to use Windows to stream from my PC to my 360 since it doesn't work AND I want to save power by not having both my high-powered PC and my home theater system on at the same time.
Anyway, most of the time GOTSent works fine. However, there are several files that once I convert to MP4, the audio is out of sync by a few seconds. It's very annoying and I have tried different GOTSent settings, but nothing works.
So is there a way to fix the MP4 if it is out of sync? The MKV file is perfectly in sync, so something must happen in the conversion process.
Or if there is a better program to use than GOTSent. I've tried using the Encode360 but that doesn't work period for some reason. Maybe it's my 64 bit version of Vista, but I couldn't get it to work.
Thanks in advance!
Fixing sound sync issues in a mkv file
By Psykro in forum EditingReplies: 12Last Post: 20th Dec 2014, 11:31 -
Are there are other apps like gotsent? Looking to convert mkv to mp4
By AndyD in forum Video ConversionReplies: 42Last Post: 8th Sep 2009, 06:09 -
Fixing Out of Sync Issues with Mp4 files?
By djfreex2 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 13:01 -
Gotsent, sync problems MKV anime, dual audio and subs to xbox 360
By TheGlow in forum Video ConversionReplies: 2Last Post: 15th Apr 2009, 19:33 -
Audio and Video out of sync when converting MKV's w/ GOTsent
By Peter25 in forum Newbie / General discussionsReplies: 3Last Post: 12th Apr 2009, 22:45
