Hiya!
What's the deal here? I snatched this recent ffmpeg build, threw ffmpeg.exe in my C:\WINNT dir, simple-style, easy access from anywhere, and still avoiding the need for another line in $PATH.
So..
Everything's fine, but where does it look for ffpresets? It (documentation) says that it will look under $HOME/.ffmpeg by pre-compiled default, under *NIX that would be like /usr/gew/.ffmpeg I suppose, but now I'm in XP.
"mkdir C:\Documents and Settings\Gew\.ffmpeg" ..???
And copy the .ffpreset files there? Tried it, but ffmpeg won't sense the presets.
Actually. I made a .ffmpeg folder with all .ffpresets (even a subdir called ffpresets, with an extra stack of the .ffpreset files, just in case), and copied it to all sorts of places. my Docs & Settings\accountname folder, the Program files\Shared files folder, the WINDOWS folder (since ffmpeg.exe is there), all varies of Local settings\Application data folders..
NOTHING works.
File for preset 'libx264-fastfirstpass' not found
..and datt wus all she wrote!
AAaawrgh! ;'( Is this an issue without solution, since I'm under an environment that (I suppose) ffmpeg wasn't ment for to begin with. Something cygwin-like? It won't find a proper $HOME-like var under Windoze?
"... -vpre "c:\folder-of-my-choice\libx264-fastfirstpass.ffpreset" ..."
Seems to work. Is this the ONLY way under Win? No possibility to have ffmpeg fetch it just by entering i.e. "-vpre fastfirstpass"..?
Thankfor for all answers!
Regards~
Results 1 to 1 of 1
Drop dead gorgeous!
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 00:33 -
how we can implement "VirtualDub" or "FFmpeg" with my C# windows applicati
By dhemittal in forum ProgrammingReplies: 0Last Post: 8th Jun 2010, 07:17 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20 -
Fairuse Wizard full version and adware "win32.rabio"
By ricardouk in forum DVD RippingReplies: 2Last Post: 13th Mar 2008, 10:56 -
How to copy/convert hidden DVD with only "Track01.cda" in dir
By vincehal in forum Newbie / General discussionsReplies: 9Last Post: 8th Nov 2007, 06:21
