Hello,
I have videos in TS and Blueray
if I want to ReMux them which format is better is it TS or M2TS for archiving on my fileserver and why? (what is the difference any way from technical perspective for later use like to convert to other format or burn them back to Blueray or even watch them on my Mac and PC)
since i use mainly Mac I have some which are muxed to MOV file (work great with quicktime)
note: ID DO NOT ASKING ABOUT ENCODING or ReENCODING, MUXING and ReMUXING ONLY
cheers,
Should make no difference for a PC, don't know about mac...........
TS is 188 byte packets, m2ts is 192 byte packets........both are Transport Stream containers. m2ts can be blu-ray compatible, ts is not.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Originally Posted by racer-x
and I should consider M2TS if I want to burn the videos to Blueray Discs?
remux from m2ts to m4v/mp4 and remove scan type MBAFF
By jlally in forum Video ConversionReplies: 9Last Post: 18th Apr 2012, 04:01 -
80% MKV remux on H.264 - M2ts remux Aero Theme
By BJ12 in forum Video ConversionReplies: 2Last Post: 12th Aug 2011, 12:59 -
Can remux .mkv to .m2ts with tsMuxer but how to do the reverse?
By MilesAhead in forum Video ConversionReplies: 8Last Post: 22nd Apr 2010, 14:27 -
demux m2ts streams and remux them together with srt subtitles
By TwilightMatt in forum Video ConversionReplies: 5Last Post: 9th Dec 2009, 11:10 -
Remux m2ts with DTS to m2ts
By eummagic in forum Blu-ray RippingReplies: 9Last Post: 13th Mar 2009, 20:03
