hey guys i want to edit a HD project is it possible in adobe premiere pro 2
plz help
Closed Thread
Results 1 to 13 of 13
rajaa, Do not post the same topic on several forums.
Please do not cross post, once is enough.
Also hijacking other's threads is a violation of our rules. In the future start a new thread if you are not replying to the original posters question.
I've created a new topic for you.
Moderator redwudz
Yes. Set up a project for the resolution you want.Originally Posted by rajaa
What is your source format? Which export format do you want?
Check your PP2 docs for import formats supported. You may have to decompress externally.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Uncompressed 1920x1080i/25fps ? There should be a project setting for that under New Project. If not create one.Originally Posted by rajaaRecommends: Kiva.org - Loans that change lives.
i have seen that i really want to out my project from adobe premiere pro 2 is there any problem in out plz
rajaa
I don't understand.Originally Posted by rajaa
What is your source video format?Recommends: Kiva.org - Loans that change lives.
Is this your camcorder?
http://www.engadget.com/2008/04/14/sonys-full-hd-pmw-ex3-camcorder-outed-at-nab/
For full XDCAM-EX support get Premiere Pro CS4 or Vegas Pro 7 or 8.
For Premiere Pro 2 you would decompress externally, or convert to a supported version of MPeg2.
http://www.dmnstockresources.com/cgi-bin/displaywwugpost.fcgi?forum=adobe_premiere&pos...1016130011.htmRecommends: Kiva.org - Loans that change lives.
yes that's my camcorder which is the best software for edit and how about premiere pro cs3 ?
rajaa
CS3 was Adobe's first shot at XDCAM-HD. XDCAM-EX is fully implemented on CS4.Originally Posted by rajaa
If you can afford a $7,000+ camcorder, you can afford a CS4 upgrade.Recommends: Kiva.org - Loans that change lives.
thanks for your help . i got the torrent of premiere pro cs4 .
You are in breach of the forum rules and are being issued with a formal warning. Mentioning downloaded Warez.
Moderator redwudzrajaa
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Exporting Premiere Pro CS4 Project - Adobe Media Encoder question
By schmickers in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jan 2012, 18:51 -
Steps to edit video in Adobe Premiere Pro CS3?
By LateFate in forum Newbie / General discussionsReplies: 0Last Post: 22nd Apr 2011, 08:21 -
Adobe Premiere Pro 2.0 project file/autosave question
By wwervd316 in forum Newbie / General discussionsReplies: 0Last Post: 20th May 2008, 19:14 -
Adobe Premiere project using AVISynth AVS scripts crashes when rendering!
By Mark001 in forum EditingReplies: 2Last Post: 10th Jun 2007, 23:25
