    Dec 2005
    Canada
    I have a problem timing subtitles on DVD files in Subtitle Workshop.
    On an old thread it was suggested using DGIndex to generate a script and load the movie that way.
    The script works in VirtualDub and MPC, but when opened in S.W. it shows a small double image and off colour.
    The .m2v file from DGIndex can be loaded ok and looks normal.
    LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DGDecode.dll")
    Video=Mpeg2Source("C:\Documents and Settings\Superuser\Desktop\dgi2\clip.d2v")
    audio=wavSource("C:\Documents and Settings\Superuser\Desktop\dgi2\clip T80 2_0ch 256Kbps 48KHz.wav")
    audiodub(video, audio)
    Dec 2005
    Canada
    Solved.
    Added line to script:
    ConvertToRGB24()
    Apr 2009
    France
    You can also use Aegisub instead SW, it load directly the d2v files without avisynth
    Dec 2005
    Canada
    Thank you, I will try it.
