Does anyone know if there is such a thing as a Firewire (IEEE 1394) compatible with a PC?
Or, more specifically, is there a Firewire (IEEE 1394) that has a USB port connection? Or, is there a device that I can connect the Firewire to in order to allow the Firewire to connect or fit into a USB port on a PC?
I have a Firewire that I have used a number of times on a Mac and there were no issues, mainly b/c Macs have a Firewire connection. However, my PC has no Firewire connections, only USB ports. I imagine there has got to be a way around this problem.
Any information provided on this topic will be much appreciated. Thank you.
Originally Posted by Ttownboy23
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Description=IEEE%2D1394%20ca...nd&Order=PRICE
What do you want to connect? Firewire can be used for DV camcorders, hard drives, audio and for networking.
Firewire to USB2 electronic adapters for specific uses exist but are not the preferred solution.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Question about Firewire>USB (Same end result)?
By sj022698 in forum Capturing and VCRReplies: 1Last Post: 24th Apr 2011, 23:37 -
Question about USB to Firewire?
By Lucid_Dream in forum ComputerReplies: 1Last Post: 4th Jan 2011, 11:37 -
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 20:32 -
Firewire Help
By danman46 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jun 2010, 20:28 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19
