    Apr 2009
    Does anyone know if it is possible to publish, render &/or compress a project on iMovie or Windows Movie Maker in FLV (Flash) Format?
    All in all, I usually just publish my projects from iMovie in QuickTime format. However, I need to know how to render the final project in "Flash Format." Any information provided on this topic will be much appreciated. Thanks!
    You can't export to flv in WMM and I doubt its possible in iMovie.
    I would just use an external convert like a free converter based on ffmpeg like winff,super, riva flv encoder. Or a commercial like flash professional, on2 flix.
    Apr 2009
    Thanks for the info.
    Do you know if it is possible to convert a QuickTime file into Flash Format? Basically, I have a project on iMovie and Windows Movie Maker that needs to be finalized in Flash Format. So, is there no possible way to do this? Could I render the project in QuickTime, then somehow convert to Flash?
    Is using an external convert all I can do?
    Thanks again!
    Jan 2007
    Republic of Texas
    Did you try any of the tools Baldrick suggested? (Winff is probably the easiest.)
