    Apr 2009
    Hi,
    I have done a Quicktime conversion with mutiple programs. Each one leaves a stamp of:
    Current Frame
    CPU Load %
    Input Size 720X540
    Output Size 720X540
    How can I get rid of this. It is not in the source file display when played in Quicktime.
    TIA
    Jojo
    Looks like ffdshow OSD. Check if you have it installed in the start menu->programs->ffdshow->ffdshow video decoder configuration(or click on the ffdshow icon in the notifications icon area while playing the video) and disable the OSD option
    Apr 2009
    I don't see "OSD" in that window.
    It says OSD in TWO places in that window. . Click on the checkbox to disable it....
    Apr 2009
    O.K. I was looking in the wrong area. I found it. That worked perfectly. Thank you!!!
    Jojo_boy
