    Apr 2009
    Please assist!!!
    Problems with video play back in VLC after MKV backup.
    The Dark Knight with similar properies plays perfect,
    where as Iron man is jittery and unplayable.
    anyone have any ideas why this is happening?
    please advise!?
    any help would be apperciated..
    General
    Complete name : H:\Video\Iron_Man_Disc_1\title00.mkv
    Format : Matroska
    File size : 24.4 GiB
    Duration : 2h 6mn
    Overall bit rate : 27.8 Mbps
    Writing application : MakeMKV v1.4.1 beta win(x86-release)
    Writing library : libmakemkv v1.4.1 beta (0.7.7/0.8.0) win(x86-release)
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Muxing mode : Container profile=Unknown@4.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 5mn
    Bit rate : 26.6 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16/9
    Frame rate : 23.976 fps
    Standard : NTSC
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.535
    Stream size : 23.4 GiB (96%)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 2h 6mn
    Bit rate mode : Constant
    Bit rate : 640 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Surround: L R, LFE
    Sampling rate : 48.0 KHz
    Stream size : 577 MiB (2%)
    Title : 3/2+1
    General
    Complete name : H:\Video\The_Dark_Knight\title00.mkv
    Format : Matroska
    File size : 26.2 GiB
    Duration : 2h 32mn
    Overall bit rate : 24.6 Mbps
    Video
    Format : VC-1
    Format profile : AP@L3
    Codec ID : WVC1
    Codec ID/Hint : Microsoft
    Duration : 2h 32mn
    Bit rate : 23.5 Mbps
    Colorimetry : 4:2:0
    Bits/(Pixel*Frame) : 0.473
    Stream size : 25.0 GiB (95%)
    Audio
    Format : AC-3
    Codec ID : A_AC3
    Duration : 2h 32mn
    Bit rate : 640 Kbps
    Stream size : 697 MiB (3%)
    Title : 3/2+1
    VLC is not the best for HD video. Try instead MPC-HC or SMPLAYER or KMPLAYER or latest ffdshow, haali media splitter, ac3filter and play using Media Player Classic.
