Does anyone know how to convert Quicktime files into DVDs? I think it's called MPEG-2 or something.
Is it also possible using an external Firewire DVD-R/RW drive, an iMac G3 and Toast 5 Titanium's DVD option? Does Toast encode the Quicktime video to DVD spec?
Toast doesn't encode to MPG2 - its DVD option is only for burning - however on a G3 you should still be able to make DVDs by encoding to DVD spec with Astarte M-Pack 3.5.1 and then use DVD Studio Pro for authoring and burning (the installer checks for G4 so you need to copy back on a G3 after install). DVDSP allows to do almost everything (multi-angle, complex menus, etc), supports various third party burners and also includes Astarte A-Pack to encode audio in Dolby AC3 format.
converting quicktime format
By nospam7676 in forum EditingReplies: 11Last Post: 8th Mar 2010, 20:45 -
Converting wmv files to play in Quicktime
By gombik in forum Video ConversionReplies: 4Last Post: 3rd Sep 2009, 09:11 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 19:42 -
Suggestion for converting hundreds of mov quicktime files
By m021478 in forum Video ConversionReplies: 0Last Post: 15th Aug 2007, 16:16 -
Help converting a quicktime file
By tecstar in forum Video ConversionReplies: 3Last Post: 17th May 2007, 18:51
