    Apr 2009
    I have a DVD that is giving me a problem, and I think I know what the problem is but need help in resolving it. Please bear w/ me while I attempt to describe the series of events I've gone through...
    DVD Shrink cannot "read" the DVD or the files if I use DVD Decrypter to rip them beforehand. First I tried other programs w/ the same result. Then I decided to try ripping each file individually to find out what was causing the problem. So I did, and it turns out the only one it can't read happens to be an insignificant 22 sec vid that displays before the menu pops up. How can I remove this little segment while keeping the DVD structure intact so that I can still copy/rip it?
    I hope this makes sense, please ask questions if I need to clarify anything. Thank you!
    I guess you have tried dvdfab decrypter? DVD SHrink and DVDDecrypter have not been updated in years.
    Apr 2009
    Yes I have tried DVDFab Decrypter as well as Pavtube.
    My guess is it's the same kind of problem you'd encounter if there was a scratch on an insignificant portion of the disc. When I preview that portion of the DVD using the ripper software I was using (Xilisoft DVD Ripper Ultimate 5) it starts skipping and repeating infinitely about 11sec into the 22sec clip. I don't need the clip in there so I'm fine taking it out if I need to.
    Apr 2009
    *bump*
    any ideas?
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    ISOPuzzle (although you may also need AnyDVD in the background), ISOBuster or CDRoller
    Read my blog here.
    I don't know why I'd never thought of this.
    Aug 2005
    Palo Alto, California USA
    Another option is to use VOBblanker on the ripped files. It may be able to remove the offending bits.
