I want to get my Mkv files onto a dvd w/ the multiple audio and subtitle streams they have intact. I plan to author the DVD using DVD Architect 4.0b. I've searched the forums for hours and can't seem to find a way to easily convert these file into a a format that DVD Architect can use. As far as I can tell my only option seems to be stripping the audio and sub files from the mkv and then converting it all back into another format (mpeg I guess). Is this correct? Is there a better format to use? Any suggestions?
I appreciate the help.
If dvd architect supports mpeg2 dvd compliance streams without reconversion I would convert to it, using for example avstompeg or favc(choose to keep the video/audio files). You have to strip the subs manually, using mkvextractgui for example.
Alas! I figured I'd have to do that. Oh well, maybe one of these days someone will design a program that will convert mkv to mpeg2 w/ all the audio and subs. Thanks for the help. I'll post again if I run into any snags.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
DVD Architect - 2 Audio Tracks?
By Dr.Who in forum Authoring (DVD)Replies: 0Last Post: 10th Oct 2010, 15:04 -
mkv subtitle encoding problems (Yes i searched and tried out everything)
By -Tom- in forum Newbie / General discussionsReplies: 5Last Post: 1st Sep 2009, 18:16 -
Video and audio track in one pass uisng TsMuxer, is it possible?
By Modify_inc in forum Blu-ray RippingReplies: 2Last Post: 6th Jul 2009, 08:21 -
DVD Architect Audio problem
By Just Mike in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2007, 02:11
